16 years agoHi
You must have signal in TMS always than press the Test JTAG Chain button , if not you have a problem with your ByteBlaster. Where are you measuring the signals? You can disconnect the signal TMS from the board maintainning the power supply and measure the TMS just in the cable? Can you check the cable in another board?
