Cannot access self-service license center
I was able to generate a license here, even thought there seems to be some new license center.
https://licensing.intel.com/eval-free-licenses
I was unable to get it to work however, even with setting the LM_LICENSE_FILE variable to the folder in which I put my license.
running
C:\Users\RF>lmutil lmdiag
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
FlexNet diagnostics on Mon 1/17/2022 12:06
License file: C:\Users\RF\AppData\Roaming/XilinxLicense\Xilinx - Copy.lic
"XC7Z020_EMBEDDED" v2022.03, vendor: xilinxd, expiry: permanent(no expiration date)
vendor_string: [email protected],XC7Z020_EMBEDDED,software,permanent,_200503949_208823071_210739961_606
uncounted nodelocked license, locked to ethernet address "b89a2a3a225d" no expiration date
TS_OK: Checkout permitted when client is using terminal client
This is the correct node for this node-locked license
Any help?
- RFI4 years ago
I was able to resolve this by adding the license file name to the environment variable path, not just the directory.
That is:
<License file folder path> /license.dat
