15 years ago
Cannnot insert breakpoints
Hi.. an Altera newbie here. I'm working with Quartus II 10sp1 & Modelsim Altera 6.5e. I have a very simple muxing program which redirects one of the two input UART ports to an output UART post based on a switch signal.
When I run the simulation, I cannot set breakpoints in my actual code; only in the testbench file and maxii-atoms.v. As a result I cannot see how the testbench signals propagate through my code.
I ran the same code on a competitor's simulator (which I'm used to) & it runs fine and the results differ big time from Altera's.
help please!
The actual code:
module e1188_try (
//UART1
output reg uart1_rx,
input uart1_tx,
output reg uart1_cts,
input uart1_rts,
//UART2
output reg uart2_rx,
input uart2_tx,
output reg uart2_cts,
input uart2_rts,
//Output UART interfaces
//UARTX
input wire uartx_rx,
output reg uartx_tx,
input wire uartx_cts,
output reg uartx_rts,
//control
input uart_switch_n //1 -> uart1, 0 -> uart2
always @ (uart_switch_n or uart1_tx or uart1_rts or uart2_tx or uart2_rts or uartx_rx or uartx_cts)
begin
if (uart_switch_n)
begin
uartx_tx = uart1_tx;
uart1_rx = uartx_rx;
uartx_rts = uart1_rts;
uart1_cts = uartx_cts;
end
else
begin
uartx_tx = uart2_tx;
uart2_rx = uartx_rx;
uartx_rts = uart2_rts;
uart2_cts = uartx_cts;
end
end
endmodule
Test bench:
module e1188_try_tb;
//UART1
//output reg uart1_rx,
//output reg uart1_cts,
reg uart1_tx;
reg uart1_rts;
//UART2
//output reg uart2_rx,
//output reg uart2_cts,
reg uart2_tx;
reg uart2_rts;
e1188_try tb(
uart1_rx,
uart1_tx,
uart1_cts,
uart1_rts,
uart2_rx,
uart2_tx,
uart2_cts,
uart2_rts,
uartx_rx,
uartx_tx,
uartx_cts,
uartx_rts,
//control
uart_switch_in //1 -> uart1, 0 -> uart2
//UARTX
//control
reg uart_switch_n; //1 -> uart1, 0 -> uart2
assign uart_switch_in = uart_switch_n;
initial
begin
uart_switch_n = 1'b0;
uart1_tx = 1'b0;
uart1_rts = 1'b1;
uart2_tx = 1'b0;
uart2_rts = 1'b1;
end
initial
begin
forever# 20000 uart_switch_n = ~uart_switch_n;
end
initial
begin
forever# 25 uart1_tx = ~uart1_tx;
end
initial
begin
forever# 50 uart1_rts = ~uart1_rts;
end
initial
begin
forever# 15 uart2_tx = ~uart2_tx;
end
initial
begin
forever# 75 uart2_rts = ~uart2_rts;
end
endmodule
1 Reply
    I figured out the above issue.
    Next issue is my RTL and gate-level simulations don't agree. Any suggestions on how to fix delays on the output?
    Feels like I'm spending too much time learning the tool.. I guess.
    Thanks though.
