Altera_ForumHonored Contributor13 years agoCan we constrain a fix delay time from pin to several nodes?Hi Dears: As the title, i want to drive a pin to 3 node in my FPGA. Can i set a constrain that the delay time from the pin to these 3 node are same? If can, how to set? Thanks in advance!
Recent Discussionslog signal to signal tapQuartus Prime Pro 26.1 - Where to find Documentation of new Signaltap featuresQuartus did not startHow can I use Quartus Pro 25.1 sopc-create-header-files tool to generate a jtag master header file?recovery timing issue
