13 years ago --- Quote Start --- The .qsf is the Quartus setting file. When needed, you may be able to improve timing by fiddling with the Quartus synthesis/fitting options. Also, sometimes manually placing some cells can also improve timing a bit. --- Quote End --- Thanks. Yes, fiddling with the Quartus synthesis/fitting options may work in some cases, but the options are very limited. You mentioned "manually placing some cells", do you mean put a register in a failed path to increase a step pipeline as I described? Thanks.
