Hi Tricky, i have tried to fix the locked and unlocked states, see how the code looks, hope i am on the right track? i am an amateur in vhdl
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity uppgift_dorr is
port( clk : in std_logic; --clock signal
reset : in std_logic; --reset signal
key_0, key_1, key_2, key_3 : in std_logic;
LEDR : out std_logic_vector (1 downto 0); -- Output LEDR
LEDG : out std_logic_vector (1 downto 0) -- Output LEDR
end uppgift_dorr;
architecture Behavioral of uppgift_dorr is
--Defines the type for states in the state machine
type state_type is (closed,opened,locked,unlocked);
--Declare the signal with the corresponding state type.
signal Current_State, Next_State : state_type;
begin
-- Synchronous Process
process(clk, reset)
begin
if( reset = '1' ) then --Synchronous Reset
Current_State <= closed;
elsif (rising_edge(clk)) then --Rising edge of Clock
Current_State <= Next_State;
end if;
end process;
-- Combinational Process
Process(Current_State, key_0, key_1, key_2, key_3)
begin
LEDG <= "00"; LEDR <= "00";
case Current_State is
when closed =>
if ( key_0 = '1' ) then
Next_State <= closed;
else
Next_State <= opened;
LEDG <= "01"; LEDR <= "01";
end if;
when opened =>
if ( key_1 = '1' ) then
else
LEDG <= "11"; LEDR <= "10";
end if;
when locked =>
if ( key_2 = '1' ) then
Next_State <= locked ;
LEDG <= "11"; LEDR <= "11";
else
LEDG <= "10"; LEDR <= "00";
end if;
when unlocked =>
if (key_3 = '1' ) then
Next_State <= unlocked;
else
LEDG <= "10"; LEDR <= "10";
end if;
end case;
end process;
end Behavioral;
