14 years ago
can some onehelp me????
hi everyone .Im a 21 year old girl from Vietnam. i have a project and have to submit it to my teacher on the 20th of May . Can you guys here help me with this project.
I would really appriciate your help^^^
the project is: design and test 4X4 bit unsigned multiplier using right shift add algorithm.
I have difficluties in describing the two registers. Can you help me write it in VHDL code? thanks very much!!!
I have attached the diagram bellow..
Hope to get nice reply from you soon:)
thanks in advance^^^
    hi Kaz . iam just back.
    oh. tomorrow is monday.(i forgot). thanks for your enthusiam.
    again,many thanks to you.
    best wishes!
    I played a bit with your algorithm and realised your output is serial.
    Here is the code that corresponds to your algorithm. It worked as far as I tested but check various values of the range 0_15 on both A,B inputs.
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    entity mult1 is
    port(
         load   : in  std_logic;
         clk    : in  std_logic;
         A      : in  std_logic_vector(3 downto 0);
         B      : in  std_logic_vector(3 downto 0);
         ready  : out std_logic;
         R      : out std_logic
    end entity;
    architecture rtl of mult1 is
    signal shift_reg1 : std_logic_vector(3 downto 0) := "0000";
    signal shift_reg2 : std_logic_vector(7 downto 0) := x"00";
    signal reg1 : std_logic_vector(7 downto 0);
    signal opA : std_logic_vector(3 downto 0);
    signal count : integer range 0 to 7 := 0;
    begin
    R <= shift_reg2(0);
    ready <= '1' when count = 5 else '0';
    reg1(7 downto 3) <= std_logic_vector(resize(unsigned(OpA),5) +  unsigned(shift_reg2(7 downto 4)));
    reg1(2 downto 0) <= shift_reg2(3 downto 1);
    process(load,clk)
    begin
    if load = '1' then
       count <= 0;
       shift_reg1 <= A; -- load input A into shift register
    elsif rising_edge(clk) then
       if count < 7 then
          count <= count + 1;
       end if;
       shift_reg1 <= '0' & shift_reg1(3 downto 1); -- shift right
       shift_reg2 <= reg1;
       if shift_reg1(0) = '1' then
           OpA <= B;
       else
           OpA <= "0000";
       end if;
    end if;
    end process;
    end rtl;
    wow! Kaz ,im grateful to you for being so kind to me.I still have 5 days before having to submit my project to my teacher . tomorrow afternoon , I have a test ahead so have to spend time for it. Dont have enough time studying my project right now.
    The code you have just posted seems suitable for my algorithm.
    I will examine it in the next few days.
    Hope you will be pleased to continue...help....
    it's 11pm and I should go to sleep now.
    Happy to have a chat with you friend Kaz ;)
    begin
    R <= shift_reg2(0);
    what's the three signals shift-reg1,shift-reg2,reg1( they are the singals between?) what does shift-reg2(0) mean?
    Is it nessecary to write :="0000" and :=x"00" at the signal shift-reg1,2
    (My teacher dont write them in the signal declaration)
    and the next code I almost don't understand ( other ways to write them easier to understand??).
    Im not very good at VHdl so the question I asked you seem a little '' stupid" .Hope you won;t despise me........
    thanks very much!!!!!!!!!!!
