15 years agoApparently Quartus isn't able to utilize the carry chain respectively LEs in arithmetic mode for synthesis, if the problem isn't presented in the expected way. I recently posted a small code example for demonstration: http://www.alteraforum.com/forum/showthread.php?t=27881
As already mentioned by Rysc, this isn't a problem for arithmetical problems, that are perfectly recognized by the Quartus synthesis. Except for educational purposes, there's no reasonable purpose to implement a low-level adder, I think. As my example shows, there are other problems, that could be considerably speeded up by using arithmetic mode, but apparently Quartus misses the chance. P.S.: I forgot to mention, that a speedwise satisfying solution for the priority problem can be found using an adder, it's also suggested in the Stratix advanced synthesis cookbook. But it involves a doubled LE amount compared to a straightforward carry chain implementation.
