17 years agoThanks Brad and GPK ...
--- Quote Start --- in the past there was some trouble with relative pathname for the MIF-files. I run run atest with Quartus 8.1 and it lookslike that the problems are solved. The MIF file is always found by the path defined in the Megawizard. --- Quote End --- that's what I've been afraid of. Haven't tried it yet, but this is an OLD project, and is pretty massive, and was done in QII v6.0 ... I don't want to run the risks of changing the compiler version and all that could potentially go wrong... I ended up just putting this legacy project in the desired path on my C:\ drive .. I should only be working on it for a couple weeks to get a "fix" done and then I'll be done with it, so it's simpler to just "give in" to the desired path than try and fix (break) everything ... :) thanks all! ..dane
