can I select a specific bit of a bus to go into another bit to other bus?
- 3 years ago
For data1x, you have to give a name to the node line of VCC for example s[0].
Then rename the bus name data1[3..0] to r[3..1],s[0]
For data0x, same have to give a name to the node line of VCC for example s[1].
Then rename the bus name data2[3..0] to r[3..2],s[1],r[0]
Attached a sample screenshot for your reference.
Sheng
Sheng
- MohamedSharfi3 years ago
Thanks it worked !
