MohamedSharfi's avatar
MohamedSharfi
3 years ago
can I select a specific bit of a bus to go into another bit to other bus?
I'm trying to take bits from output to input of the bus . example : result or r[3..0] = 0000 if my ones selector 0 new output[3..0] is 0001 if my ones is high new output[3..0] is 0010 i t...
  • ShengN_altera's avatar
    3 years ago
    For data1x, you have to give a name to the node line of VCC for example s[0].
    Then rename the bus name data1[3..0] to r[3..1],s[0]
    For data0x, same have to give a name to the node line of VCC for example s[1].
    Then rename the bus name data2[3..0] to r[3..2],s[1],r[0]
    Attached a sample screenshot for your reference.
    Sheng
