can I select a specific bit of a bus to go into another bit to other bus?
- 3 years ago
For data1x, you have to give a name to the node line of VCC for example s[0].
Then rename the bus name data1[3..0] to r[3..1],s[0]
For data0x, same have to give a name to the node line of VCC for example s[1].
Then rename the bus name data2[3..0] to r[3..2],s[1],r[0]
Attached a sample screenshot for your reference.
Sheng
how should the tool know which r[] bit connects to which data1[] and data2[] bit?
Use wire or soft symbol to connect nets.
- MohamedSharfi3 years ago
sorry i didnt get what you mean but i need vcc to connect with data1[0] and r[1] to data1[1] ... etc in the same order starting top data1[0] untill data1[3]
same down first bit r[0] to data2[0] .....
