12 years ago --- Quote Start --- The design is based on the "Dual-Port ROM" modified slightly with the "True Dual-Port RAM (dual-clock)" placed in "Insert Template->VHDL->Full Designs->RAMs and ROMs" path. --- Quote End --- Why? The NCO design should work fine with the original dual-port ROM template. Without setting additional parameters, a true dual-clock RAM design will use double the RAM amount on Cyclone II to be compatible with revision A chips.
