12 years agoC++ support for AOCL
Does the OpenCL SDK support C++? If so, what are the limitations? The prorgramming guide isn't quite clear on C++ support (at least, from a quick glance-through)
If you want to use cl.hpp as mentioned above, make sure it's the header supporting the OpenCL spec 1.0 and 1.1: http://www.khronos.org/registry/cl/api/1.1/cl.hpp.
