13 years agoOk, so here's my new code. Hopefully this is more appropriately written.
EDIT: This doesn't work, obviously. It doesn't drive the motor because cw_45 and ccw_180 are low to begin so it just throws it into the STOP state during the 'else' of the second if statement and keeps it there. Suggestions on how to fix?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity motor_demo is
port( clk: in std_logic;
RST, EN, CTRL, HALF, CW, Step_clk: out std_logic;
sw: in std_logic_vector(0 to 4);
sw_check: out std_logic_vector(0 to 4)
end motor_demo;
architecture stm of motor_demo is
type motor_action is (STOP, CWISE, CCWISE);
signal motor_state: motor_action := CWISE;
signal stepcount: integer := 0;
signal clk_div: std_logic;
signal drive: std_logic := '0';
signal cw_45, ccw_180: std_logic := '0';
begin
-- Clock divider for stepper action
clk_divider: entity work.clk_divide port map(clk, clk_div);
-- Motor control lines
EN <= '1';
RST <= '1';
CTRL <= '1';
HALF <= '1';
-- switch debugging
sw_check <= sw;
-- driving the step clock
with drive select
step_clk <= clk_div when '1',
'0' when '0',
'0' when others;
process(clk_div, motor_state, sw) is
begin
if rising_edge(clk_div) then
if sw(0) = '0' then
motor_state <= CWISE;
elsif sw(1) = '0' then
motor_state <= CCWISE;
elsif sw(2) = '0' then
motor_state <= STOP;
elsif sw(3) = '0' then
cw_45 <= '1';
elsif sw(4) = '0' then
ccw_180 <= '1';
end if;
-- counter conditions
if cw_45 = '1' AND stepcount < 49 then
stepcount <= stepcount + 1;
elsif ccw_180 = '1' AND stepcount < 199 then
else
ccw_180 <= '0';
cw_45 <= '0';
end if;
case motor_state is
when STOP =>
drive <= '0';
stepcount <= 0;
when CWISE =>
drive <= '1';
CW <= '1';
when CCWISE =>
drive <= '1';
CW <= '0';
end case;
end if;
end process;
end stm;
