14 years agoGot it, but I don't know the intricacies(such as if the delays vary over PVT, does it matter, or is it fine if they all vary together)? Anyway, if you're driving out from a flip-flop, the best method is to use the output flip-flops in the I/O cell. General routing delays in the FPGA will be more subject to variaion, where the global clock tree is designed for low-skew(and jitter should be low).
