14 years agoHello Rysc:
My case is of spercial application. I will use FPGA to generate a signal which feeds TDC chips. Then if there are hundreds of ps timing variation would be an issue for my case. That's why i need the route inside FPGA of this signal to be fixed like PCB trace. I hope that i have explained my question clearly. Thanks
