14 years agoReplicate the output register 22 times(either manually or with assignment) so the I/O output register can be used and it will be fed by a global clock tree. I wrote the following document that might help(it's a different topic, but somewhat related)
http://www.alterawiki.com/wiki/register_duplication_for_timing_closure That will give you the least amount of skew, and much better than trying to get the router to add/subtract delays to get minimally skew to 22 locations.
