Bus Error while booting FPGA Hardwaare
We use "10AS048E3F29I2SG" (Arria 10) device.
While booting the fpga hardware, in serial prints following bus error is coming
Fail: noc_idleack = 0x01110111 mask_noc = 0x00100111
Kernel image @ 0x008000 [ 0x000000 - 0x4fd948 ]
prg <page> <reg>
[ 108.745414] Unhandled fault: external abort on non-linefetch (0x818) at 0xb6c87240
[ 108.752962] pgd = ed9e8000
[ 108.755656] [b6c87240] *pgd=7fcd5831
Bus error
Plz analyze the issue.Whether this is hardware or software issue?
Kindly give a solution for this asap.
- EBERLAZARE_I_Intel
How did you build your bootloader?
Also, could you share your full booting logs?
Which version of Uboot are you using?
Have you had successful logs in the past for this board?
- Shwetha_G_S
We are using U-Boot 2014.10 version.
Full booting logs have been attached.
We had successful logs in the past for this same arria 10 device
Do you have any update?
