Shwetha_G_S
3 years agoBus Error while booting FPGA Hardwaare
We use "10AS048E3F29I2SG" (Arria 10) device.
While booting the fpga hardware, in serial prints following bus error is coming
Fail: noc_idleack = 0x01110111 mask_noc = 0x00100111 Kernel image @ ...
EBERLAZARE_I_Intel
3 years agoHi,
How did you build your bootloader?
Also, could you share your full booting logs?
Which version of Uboot are you using?
Have you had successful logs in the past for this board?
- Shwetha_G_S3 years ago
We are using U-Boot 2014.10 version.
Full booting logs have been attached.
We had successful logs in the past for this same arria 10 device
Kindly give a solution for this asap.
