14 years agoBuilding for Nios without using the Nios II command shell
Hi All,
I am currently automating a rather complex build system and need to be able to build for multiple targets (including the much hated Xilinx :) ). I am having an issue where I need to have cygwin installed for other builds on the same system but get the following error when I launch a Nios II command shell
Removing old PATH, because a copy of
. cygwin1.dll was found at:
. /cygdrive/c/cygwin/bin/cygwin1.dll
. You can remove or rename it to avoid conflict.
This resets my Path and stops me picking up some tools that are not in the build directory. Platform is windows :( but I have no choice in this. From what I can see the only solution is to rename my current install of cygwin (something I don't want to do). Does anyone know another way around this? or does anyone know how I can build for Nios without using the nios II command shell? i.e use normal windows cmd shell and set up any variables I require? thanks, G
