I was thinking that the path issue wasn't the problem because it gives an error before that, but I'll have to fix the path problem and see
took me a while to realize that I needed to restart visual studio to get the path changes I had made to come into effect. I fixed that and it still doesn't work. Programming cable is fine, I think the problem is where it decides to abort the process
--- Quote Start ---
Querying platform for info:==========================
CL_PLATFORM_NAME = Altera SDK for OpenCL
CL_PLATFORM_VENDOR = Altera Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 14.0
Querying device for info:
CL_DEVICE_NAME = s5phq_d8 : S5PHQ
CL_DEVICE_VENDOR = Bittware Inc
CL_DEVICE_VENDOR_ID = 4466
CL_DEVICE_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 14.0
CL_DRIVER_VERSION = 14.0
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0
CL_DEVICE_GLOBAL_MEM_SIZE = 0
CL_DEVICE_IMAGE_SUPPORT = false
CL_DEVICE_LOCAL_MEM_SIZE = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000
CL_DEVICE_MAX_COMPUTE_UNITS = 1
CL_DEVICE_MAX_CONSTANT_ARGS = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 2147483648
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order? = false
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
MMD INFO : [acl0] New FPGA design has different periphery from programmed design.
MMD INFO : AOCX base and CvP periphery hashes differ. Programming will fail in hardware, so aborting.
MMD INFO : executing "quartus_pgm -c 1 -m jtag -o "P;reprogram_temp.sof@1""
Error (213013): Programming hardware cable not detected
MMD INFO : Link currently operating at 5 GT/s.
MMD INFO : Link operating at Gen 2 with 8 lanes.
MMD INFO : Expected peak bandwidth = 4000 MB/s
mmd program_device: Board reprogram failed
--- Quote End ---
