11 years agoI was thinking that the path issue wasn't the problem because it gives an error before that, but I'll have to fix the path problem and see
took me a while to realize that I needed to restart visual studio to get the path changes I had made to come into effect. I fixed that and it still doesn't work. Programming cable is fine, I think the problem is where it decides to abort the process --- Quote Start --- Querying platform for info:========================== CL_PLATFORM_NAME = Altera SDK for OpenCL CL_PLATFORM_VENDOR = Altera Corporation CL_PLATFORM_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 14.0 Querying device for info: ======================== CL_DEVICE_NAME = s5phq_d8 : S5PHQ CL_DEVICE_VENDOR = Bittware Inc CL_DEVICE_VENDOR_ID = 4466 CL_DEVICE_VERSION = OpenCL 1.0 Altera SDK for OpenCL, Version 14.0 CL_DRIVER_VERSION = 14.0 CL_DEVICE_ADDRESS_BITS = 64 CL_DEVICE_AVAILABLE = true CL_DEVICE_ENDIAN_LITTLE = true CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768 CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0 CL_DEVICE_GLOBAL_MEM_SIZE = 0 CL_DEVICE_IMAGE_SUPPORT = false CL_DEVICE_LOCAL_MEM_SIZE = 16384 CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000 CL_DEVICE_MAX_COMPUTE_UNITS = 1 CL_DEVICE_MAX_CONSTANT_ARGS = 8 CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 2147483648 CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3 CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 8192 CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024 CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4 CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2 CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0 Command queue out of order? = false Command queue profiling enabled? = true Using AOCX: hello_world.aocx MMD INFO : [acl0] New FPGA design has different periphery from programmed design. MMD INFO : AOCX base and CvP periphery hashes differ. Programming will fail in hardware, so aborting. MMD INFO : executing "quartus_pgm -c 1 -m jtag -o "P;reprogram_temp.sof@1"" Error (213013): Programming hardware cable not detected Error (213013): Programming hardware cable not detected Error (213013): Programming hardware cable not detected MMD INFO : Link currently operating at 5 GT/s. MMD INFO : Link operating at Gen 2 with 8 lanes. MMD INFO : Expected peak bandwidth = 4000 MB/s mmd program_device: Board reprogram failed --- Quote End ---
