SimonT's avatar
SimonT
1 year ago
Building a composed component with a instance that has a SYSTEM_INFO parameter
I have an integrated circuit connected to the FPGA. The circuit has an SPI interface and various other interfaces. For portablity of my HDL and SW code I want to use platform designer and build a composed component with a SW driver to control the device in various applications.
For initial testing I startet with a simple _hw.tcl file wich includes only the SPI master and exports all it's interfaces.
package require -exact qsys 16.1
set_module_property name my_composed_component
set_module_property COMPOSITION_CALLBACK composed_component
proc composed_component {} {
# Instances
add_instance spiInstance altera_avalon_spi
# add_instance myComponent_A; To be added later
# add_instance myComponent_B; To be added later
# Interfaces
add_interface clk clock end
add_interface reset reset end
add_interface spi_control_port avalon slave
add_interface spi_irq interrupt end
add_interface external conduit end
# Connections
set_interface_property clk EXPORT_OF spiInstance.clk
set_interface_property reset EXPORT_OF spiInstance.reset
set_interface_property spi_control_port EXPORT_OF spiInstance.spi_control_port
set_interface_property spi_irq EXPORT_OF spiInstance.irq
set_interface_property external EXPORT_OF spiInstance.external
Including the component in Platform designer works perfectly fine, but I am not able to generate the HDL code. During generation the following errors pop up.
Info: spiInstance: Starting RTL generation for module 'niosv_my_composed_component_0_spiInstance'
Info: spiInstance:   Generation command is [exec /home/simon/intelFPGA_lite/23.1std/quartus/linux64/perl/bin/perl -I /home/simon/intelFPGA_lite/23.1std/quartus/linux64/perl/lib -I /home/simon/intelFPGA_lite/23.1std/quartus/sopc_builder/bin/europa -I /home/simon/intelFPGA_lite/23.1std/quartus/sopc_builder/bin -I /home/simon/intelFPGA_lite/23.1std/quartus/../ip/altera/sopc_builder_ip/common -I /home/simon/intelFPGA_lite/23.1std/quartus/../ip/altera/sopc_builder_ip/altera_avalon_spi -- /home/simon/intelFPGA_lite/23.1std/quartus/../ip/altera/sopc_builder_ip/altera_avalon_spi/generate_rtl.pl --name=niosv_my_composed_component_0_spiInstance --dir=/tmp/alt0333_2429507840219227742.dir/0008_spiInstance_gen/ --quartus_dir=/home/simon/intelFPGA_lite/23.1std/quartus --verilog --config=/tmp/alt0333_2429507840219227742.dir/0008_spiInstance_gen//niosv_my_composed_component_0_spiInstance_component_configuration.pl  --do_build_sim=0  ]
Info: spiInstance: Illegal division by zero at /home/simon/intelFPGA_lite/23.1std/quartus/../ip/altera/sopc_builder_ip/altera_avalon_spi/em_spi_qsys.pm line 330.
Info: spiInstance: Done RTL generation for module 'niosv_my_composed_component_0_spiInstance'
Error: spiInstance: Failed to find module niosv_my_composed_component_0_spiInstance
Info: spiInstance: "my_composed_component_0" instantiated altera_avalon_spi "spiInstance"
Error: Generation stopped, 108 or more modules remaining
Info: niosv: Done "niosv" with 40 modules, 16 files
Error: qsys-generate failed with exit code 1: 2 Errors, 3 Warnings
I think the problem that the spi instance is not found results from
I have checked the content of the PM file. In line 330 the following code is executed
my $ss_delay_quantum = $CLOCKDIV / $clock_freq / 2;
The clock frequency is a SYSTEM_INFO based parameter
add_parameter inputClockRate LONG
set_parameter_property inputClockRate DEFAULT_VALUE {0}
set_parameter_property inputClockRate DISPLAY_NAME {inputClockRate}
set_parameter_property inputClockRate VISIBLE {0}
set_parameter_property inputClockRate AFFECTS_GENERATION {1}
set_parameter_property inputClockRate HDL_PARAMETER {0}
set_parameter_property inputClockRate SYSTEM_INFO {clock_rate clk}
set_parameter_property inputClockRate SYSTEM_INFO_TYPE {CLOCK_RATE}
set_parameter_property inputClockRate SYSTEM_INFO_ARG {clk}
It seems that the clock frequency is not set correct and remains at it's default value 0.
After a bit of research I have found another ticket with a very similar issue. Also in this case there is an issue with a component instance that makes use of a SYSTEM_INFO parameter.
I think that the issue I am observing here is a bug. It seems that it is simply impossible to use component instances that relay on SYSTEM_INFO parameters within a composed component.
Is there any way to use instances with SYSTEM_INFO parameter within a composed component?
If not, is there any other method to create a custom component that includes multiple component instances and can be linked to a single _sw.tcl driver?
Version Information: Quartus Prime Lite 23.1
  • RichardT_altera's avatar
    RichardT_altera
    I think I almost understand what you're trying to do here. The component you're attempting to add is the SPI (4-Wire Serial) Altera FPGA IP (altera_avalon_spi). With the usual flow by adding the component manually into the system, the Platform Designer (PD) is able to generate the HDL successfully.
    I added the SPI (4-Wire Serial) Altera FPGA IP component, resolved any errors as needed, and then went to File > Export System as .tcl Component. PD will generated a _hw.tcl file.
    If you cross-check the _hw.tcl, you'll notice that there are parameter values set in the _hw.tcl, which I suspect are missing in your current my_composed_component —and that’s likely what causes the error message during your composed_component HDL generation.
    Richard Tan
    # _hw.tcl file for test
    package require -exact qsys 14.0
    # module properties
    set_module_property NAME {test_export}
    set_module_property DISPLAY_NAME {test_export_display}
    # default module properties
    set_module_property VERSION {1.0}
    set_module_property GROUP {default group}
    set_module_property DESCRIPTION {default description}
    set_module_property AUTHOR {author}
    set_module_property opaque_address_map false
    proc compose { } {
    # Instances and instance parameters
    # (disabled instances are intentionally culled)
    add_instance clk_0 clock_source 24.1
    set_instance_parameter_value clk_0 {clockFrequency} {50000000.0}
    set_instance_parameter_value clk_0 {clockFrequencyKnown} {1}
    set_instance_parameter_value clk_0 {resetSynchronousEdges} {NONE}
    add_instance spi_0 altera_avalon_spi 24.1
    set_instance_parameter_value spi_0 {clockPhase} {0}
    set_instance_parameter_value spi_0 {clockPolarity} {0}
    set_instance_parameter_value spi_0 {dataWidth} {8}
    set_instance_parameter_value spi_0 {disableAvalonFlowControl} {0}
    set_instance_parameter_value spi_0 {insertDelayBetweenSlaveSelectAndSClk} {0}
    set_instance_parameter_value spi_0 {insertSync} {0}
    set_instance_parameter_value spi_0 {lsbOrderedFirst} {0}
    set_instance_parameter_value spi_0 {masterSPI} {1}
    set_instance_parameter_value spi_0 {numberOfSlaves} {1}
    set_instance_parameter_value spi_0 {syncRegDepth} {2}
    set_instance_parameter_value spi_0 {targetClockRate} {128000.0}
    set_instance_parameter_value spi_0 {targetSlaveSelectToSClkDelay} {0.0}
    # connections and connection parameters
    add_connection clk_0.clk spi_0.clk clock
    add_connection clk_0.clk_reset spi_0.reset reset
    # exported interfaces
    add_interface clk clock sink
    set_interface_property clk EXPORT_OF clk_0.clk_in
    add_interface reset reset sink
    set_interface_property reset EXPORT_OF clk_0.clk_in_reset
    add_interface spi_0_external conduit end
    set_interface_property spi_0_external EXPORT_OF spi_0.external
    add_interface spi_0_irq interrupt sender
    set_interface_property spi_0_irq EXPORT_OF spi_0.irq
    add_interface spi_0_spi_control_port avalon slave
    set_interface_property spi_0_spi_control_port EXPORT_OF spi_0.spi_control_port
    # interconnect requirements
    set_interconnect_requirement {$system} {qsys_mm.clockCrossingAdapter} {HANDSHAKE}
    set_interconnect_requirement {$system} {qsys_mm.enableEccProtection} {FALSE}
    set_interconnect_requirement {$system} {qsys_mm.insertDefaultSlave} {FALSE}
    set_interconnect_requirement {$system} {qsys_mm.maxAdditionalLatency} {1}
  • SimonT's avatar
    SimonT
    Thanks Richard.
    I did not knew that it is possible to create the _hw.tcl directly from platform designer. That is brilliant and simplify things a lot.
    I have now successfully created a composed with one altera_avalon_spi and 2 altera_avalon_pio instances and called it myCircuit_hw.tcl
    Additionally I have created a myCircuit_sw.tcl for the component.
    The component is integrated in a parent qsys file with niosv processor and compiles.
    When I generate the BSP the, BSP editor shows three Modules, but not the driver defined in the myCircuit_sw.tcl
    All three modules have some dependecy. Therefore I want to not only link them in HW, but also have a single SW driver, that handles the communication with the SPI and both PIOs.
    RichardT_altera
    I saw that you created a new post for your follow-up question.
    Since the initial question has been resolved, I will be transitioning this thread to community support.
    If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
    Richard Tan
