Building a composed component with a instance that has a SYSTEM_INFO parameter
I think I almost understand what you're trying to do here. The component you're attempting to add is the SPI (4-Wire Serial) Altera FPGA IP (altera_avalon_spi). With the usual flow by adding the component manually into the system, the Platform Designer (PD) is able to generate the HDL successfully.
I added the SPI (4-Wire Serial) Altera FPGA IP component, resolved any errors as needed, and then went to File > Export System as .tcl Component. PD will generated a _hw.tcl file.
If you cross-check the _hw.tcl, you'll notice that there are parameter values set in the _hw.tcl, which I suspect are missing in your current my_composed_component —and that’s likely what causes the error message during your composed_component HDL generation.
Richard Tan
# _hw.tcl file for test
package require -exact qsys 14.0
# module properties
set_module_property NAME {test_export}
set_module_property DISPLAY_NAME {test_export_display}
# default module properties
set_module_property VERSION {1.0}
set_module_property GROUP {default group}
set_module_property DESCRIPTION {default description}
set_module_property AUTHOR {author}
set_module_property COMPOSITION_CALLBACK compose
set_module_property opaque_address_map false
proc compose { } {
# Instances and instance parameters
# (disabled instances are intentionally culled)
add_instance clk_0 clock_source 24.1
set_instance_parameter_value clk_0 {clockFrequency} {50000000.0}
set_instance_parameter_value clk_0 {clockFrequencyKnown} {1}
set_instance_parameter_value clk_0 {resetSynchronousEdges} {NONE}
add_instance spi_0 altera_avalon_spi 24.1
set_instance_parameter_value spi_0 {clockPhase} {0}
set_instance_parameter_value spi_0 {clockPolarity} {0}
set_instance_parameter_value spi_0 {dataWidth} {8}
set_instance_parameter_value spi_0 {disableAvalonFlowControl} {0}
set_instance_parameter_value spi_0 {insertDelayBetweenSlaveSelectAndSClk} {0}
set_instance_parameter_value spi_0 {insertSync} {0}
set_instance_parameter_value spi_0 {lsbOrderedFirst} {0}
set_instance_parameter_value spi_0 {masterSPI} {1}
set_instance_parameter_value spi_0 {numberOfSlaves} {1}
set_instance_parameter_value spi_0 {syncRegDepth} {2}
set_instance_parameter_value spi_0 {targetClockRate} {128000.0}
set_instance_parameter_value spi_0 {targetSlaveSelectToSClkDelay} {0.0}
# connections and connection parameters
add_connection clk_0.clk spi_0.clk clock
add_connection clk_0.clk_reset spi_0.reset reset
# exported interfaces
add_interface clk clock sink
set_interface_property clk EXPORT_OF clk_0.clk_in
add_interface reset reset sink
set_interface_property reset EXPORT_OF clk_0.clk_in_reset
add_interface spi_0_external conduit end
set_interface_property spi_0_external EXPORT_OF spi_0.external
add_interface spi_0_irq interrupt sender
set_interface_property spi_0_irq EXPORT_OF spi_0.irq
add_interface spi_0_spi_control_port avalon slave
set_interface_property spi_0_spi_control_port EXPORT_OF spi_0.spi_control_port
# interconnect requirements
set_interconnect_requirement {$system} {qsys_mm.clockCrossingAdapter} {HANDSHAKE}
set_interconnect_requirement {$system} {qsys_mm.enableEccProtection} {FALSE}
set_interconnect_requirement {$system} {qsys_mm.insertDefaultSlave} {FALSE}
set_interconnect_requirement {$system} {qsys_mm.maxAdditionalLatency} {1}
