Bug report: synthesis optimizes out the signal if data type is declared in generic package
Dear Ean,
you have not provided a solution to the bug, you have provided a workaround. By avoiding the use of generic package you have avoided the bug.
In the case I have presented, the Intel Quartus synthesis generates wrong design. It does not produce any error messages. And I also do not want to consider changing my architecture, because the code I wrote is valid VHDL and I expect Quartus to produce correct results from it. It also simulates fine in Modelsim.
I also do not need a workaround.
I just wanted to report a bug in the synthesis tool and to get it fixed.
Let's try again. Below I have provided an example, where the synthesis tool wrongly removes the whole connection. No errors are generated in Quartus.
I can also simulate this file in Modelsim and the connection is there.
Can you explain the behavior of the synthesis tool? Why is the whole connection to o_bug removed in this case?
library ieee; use ieee.std_logic_1164.all; use work.parallel_pixel_type_pkg.all; entity bug is port( i : in std_logic_vector(17 downto 0); o_bug : out std_logic_vector(16 downto 0) ); end entity; architecture rtl of bug is signal sp : test_type_t; begin sp.pixel_data(0) <= i; o_bug <= sp.pixel_data(0)(16 downto 0); end rtl;
If you need any more information, let me know.
Ivan
