EGrub
7 years agoBUG in simulation library for dcfifo_mixed_widths with Modelsim
If a dcfifo_mixed_widths is used (because I need the mixed width) but write and read side getting the same clock signal then simulation fails. With the read request signal the output changes immedia...
KhaiChein_Y_Intel
7 years agoHi,
I created two test cases. The behavior for both test cases are the same. The output signal is high at positive edge of the rdclk when rdreq is high. Attached are the waveforms for same rdclk & wrclk and different rdclk & wrclk.
