BUG in simulation library for dcfifo_mixed_widths with Modelsim
Hi YY!
Please read my first post carefully.
Here are the parameters:
dcfifo_mixed_widths dcfifo_mixed_widths_component (
.rdclk (rdclk),
.wrclk (wrclk),
.wrreq (wrreq),
.aclr (aclr),
.data (data),
.rdreq (rdreq),
.wrempty (sub_wire0),
.wrfull (sub_wire1),
.q (sub_wire2),
.rdempty (sub_wire3),
.rdfull (sub_wire4),
.wrusedw (sub_wire5),
.rdusedw (sub_wire6));
defparam
dcfifo_mixed_widths_component.add_usedw_msb_bit = "ON",
dcfifo_mixed_widths_component.intended_device_family = "Cyclone V",
dcfifo_mixed_widths_component.lpm_numwords = P_BUFFER_SIZE,
dcfifo_mixed_widths_component.lpm_showahead = "ON",
dcfifo_mixed_widths_component.lpm_type = "dcfifo_mixed_widths",
dcfifo_mixed_widths_component.lpm_width = P_INPUT_WIDTH,
dcfifo_mixed_widths_component.lpm_widthu = P_INPUT_FILL_WIDTH,
dcfifo_mixed_widths_component.lpm_widthu_r = P_OUT_FILL_WIDTH,
dcfifo_mixed_widths_component.lpm_width_r = P_OUTPUT_WIDTH,
dcfifo_mixed_widths_component.overflow_checking = "ON",
dcfifo_mixed_widths_component.rdsync_delaypipe = 4,
dcfifo_mixed_widths_component.read_aclr_synch = "ON",
dcfifo_mixed_widths_component.underflow_checking = "ON",
dcfifo_mixed_widths_component.use_eab = "ON",
dcfifo_mixed_widths_component.write_aclr_synch = "ON",
dcfifo_mixed_widths_component.wrsync_delaypipe = 4;
and a screenshot from Modelsim showing all signals from that dcfifo:
You can see there the output changes immediately with the same clock the read request is captured, I marked it with the cursor.
Erich
