tfm's avatar
tfm
4 years ago
box pups up : specify the simulation tool executable location
  • Hi,
  • I downloaded and installed: Quartus Prime Pro,
    I am ussing the Cyclone 10GX (so can complile free)
    I trying to use simulation : Tools/Launch simulation library compiler
    I fill in executable location (map) C:/intelFPGA_pro/22.2/questa_fse/win64
    then at pressing start : a box pups up : specify the simulation tool executable location.
    ...so at this point i am stuck..
    Theo
  • You should get something similar like this if setup correctly.
    Do you see the same thing?
    You should not see any red line warning message as well.
    Which Quartus Pro version you are using?
    • tfm's avatar
      tfm
      Thanks Richard.
      I fill in :
      ==> i Do have a red line: Specify the simulation tool executable location. *e.g. @QUESTASIM_INSTALLDIR/win64/vsim.exe)
      The quartus prime version is: 22.2.0 Build 94 06/08/2022 SC Pro Edition
      Looking forward to your response..
      Theo Mulder
  • Can you check if the Questasim vsim.exe is installed/found at that directory path?
    If the issue persists, I suggest to reinstall the Questasim.
  • I have yet to receive any response from you in regards to my last reply.
    With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Richard Tan
    p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos and select the best solution.
  • Hello,
    This question resembles my problem exactly. Since there never was a satisfactory answer and I am pretty frustrated, I'll try to reopen this thread in hopes of getting a solution.
    QuestaSim Starter Edition starts in stand-alone mode fine, so is not a licensing issue.
    The path is 100% verified as I have went directly to the shortcut file location that launched the stand-alone QuestaSim.
    But when attempting Tools -> Launch Simulation Library Compiler
    I have tried with and without vsim.exe. I have tried '\' and '/'. The file executable is absolutely present. So there is probably something else wrong and this is a misleading error message. But I don't know what to do next. My license is verified. I wouldn't think I would have to do re-install when the stand-alone functions fine. What does anyone think I should try next?
    Thanks..
  • Axel-K's avatar
    Axel-K
    I have exactly the same problem. Have you found a solution?
    Thank you.
    • milenko121175's avatar
      milenko121175
      Hello Axel-K,
      Yes. I beat my head on the wall for a day or so and then went back to reinstall as a last resort and that is where I found the solution.
      During the installation, I didn't think I needed the 'full' or 'paid' version? I just installed the FSE version. When I went back to the installer, I had the long shot idea of installing both, so there are now questa_fe and questa_fse directories as shown.
      Then simply select the questa_fse directory as shown below:
      and.... success...
      I wish you luck!!
      Mil
      • Axel-K's avatar
        Axel-K
        Hello Mil,
        Thanks a lot for your feedback.
        I tried it, but it is still not working. There is a strange difference in the error messages.
        Your error message:
        My error message:
        Asking you for the 64bit version, but asking me for the 32bit version. But I'm not aware that I could select it during installation. I have a new computer, so I'm sure that 64bit should be no problem.
        I love your original solution, do you have a second one handy?
