SYosh17
6 years agoBoard Test System error "FPGA is not detected in the Jtag Chain"
Hi, I have Cyclone 10 GX FPGA Development Kit and want to use Board Test System according to the Intel Cyclone 10 GX FPGA Development Kit User Guide. However, they did not work with error “FPGA is ...
AR_A_Intel
6 years agoCould you try this sequence:
1. restart PC, 2.run Programmer as administrator, 3. open nios II command prompt (not admistrator). 4. jtagconfig
SYosh17
6 years agoThank you for your replay.
I tried suggested sequence and it works!
I also tried to run Board Test System as administrator after lunch Programmer.
The board test system started successfully.
However, executing "Compose with GPIO / FLASH design" failed.
I found some error in the “bts_log.txt”. I attached the file.
1 21, 2020 10:05:08 AM com.intel.bts.VersionSelector readInifile
Error: java.io.FileNotFoundException: bts.ini
1 21, 2020 10:05:21 AM com.intel.bts.SysConService <init>
Error: java.io.IOException: Get master service paths failed! Device: "/devices/10CX220Y@2#USB-1" Type: Could you please tell me how to configure using board test system.
