SYosh17
6 years agoBoard Test System error "FPGA is not detected in the Jtag Chain"
Hi, I have Cyclone 10 GX FPGA Development Kit and want to use Board Test System according to the Intel Cyclone 10 GX FPGA Development Kit User Guide. However, they did not work with error “FPGA is ...
AR_A_Intel
6 years agoIf you see the similar issue ! warning as above [open Nios II prompt Command, and execute command "jtagconfig".], it probably the windows issue.
Solution:
Open Quartus / Quartus Programmer as Run as Administrator. This should help you to detect the device.
- SYosh176 years ago
Thank you for your reply.
Before performing the following, I opened quartus prime pro as administrator.
I tried running the Cyclone X Board Test System as administrator, but it still did not work. The error is also still “FPGA is not detected in the Jtag Chain.”.
I also tried running jtagconfig command as administrator, the result is same as the one I posted last time.
Could you tell me how to solve this error?
