mcd's avatar
mcd
7 months ago
Board-Aware Flow autoring
I'm following the guide for Board-Aware Flow to create a board preset: https://docs.altera.com/r/docs/757339/22.4/an-988-using-the-board-aware-flow-in-the-intel-quartus-prime-pro-edition-software/step-5-compile-and-verify-the-design
Is there a way to make the board preset and IP presets persistent between projects? Are there any more documentation regarding custom boards and Board-Aware Flow?
  • The board preset file (.xml) can be used in any project.  Just put it in a location visible to Quartus/PD for each project.  IP preset files (.qprs) are put in a presets folder by default so should also be available between projects.
  • sstrell's avatar
    sstrell
