14 years ago
Blocking/Nonblocking assignments in SystemVerilog always block
In Verilog, a commonly known rule states that in always blocks, only blocking or only nonblocking assignments should be used, not a mix in one block.
Could anybody tell whether a similar rule is valid in SystemVerilog for always/always_comb/always_ff blocks? I have seen worked-out designs of an experienced designer and well known author of SV textbooks with a mixture of assignments type in one block, and I am not sure whether it is acceptable in SV, or, possibly, I do not understand something in this language that admits such use of assignments in SV blocks.
Thank in advance.
1 Reply
    LRM says: The always_ff procedure imposes the restriction that it contains one and only one event control and no blocking timing controls. Variables on the left-hand side of assignments within an always_ff procedure, including variables from the contents of a called function, shall not be written to by any other process.
    Software tools should perform additional checks to warn if the behavior within an always_ff procedure does not represent sequential logic.
    A blocking assignment is not a blocking timing control. Blocking timing controls are# , @, wait, and task calls. Thus,
    always_ff @(posedge clk) begin // LEGAL
    logic temp;
    temp=a && b; // local evaluation, for later usage
    if(temp) c <= d;
    end
    always_ff @(posedge clk) begin // ILLEGAL
    logic temp;
    # 1 // <<<< ILLEGAL
    if(temp) e <= d;
    end
    Ben Cohen (831) 345-1759
    http://www.systemverilog.us/ ben@systemverilog.us
    * SystemVerilog Assertions Handbook, 2nd Edition, 2010 ISBN 878-0-9705394-8-7
    * A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
    * Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
    * Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 0-9705394-2-8
    * Component Design by Example, 2001 ISBN 0-9705394-0-1
    * VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
    * VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
