14 years agoLRM says: The always_ff procedure imposes the restriction that it contains one and only one event control and no blocking timing controls. Variables on the left-hand side of assignments within an always_ff procedure, including variables from the contents of a called function, shall not be written to by any other process.
Software tools should perform additional checks to warn if the behavior within an always_ff procedure does not represent sequential logic. A blocking assignment is not a blocking timing control. Blocking timing controls are# , @, wait, and task calls. Thus, always_ff @(posedge clk) begin // LEGAL logic temp; temp=a && b; // local evaluation, for later usage if(temp) c <= d; end always_ff @(posedge clk) begin // ILLEGAL logic temp; # 1 // <<<< ILLEGAL temp=a && b; // local evaluation, for later usage if(temp) e <= d; end -------------------------------------------------------------------------- Ben Cohen (831) 345-1759 http://www.systemverilog.us/ ben@systemverilog.us * SystemVerilog Assertions Handbook, 2nd Edition, 2010 ISBN 878-0-9705394-8-7 * A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5 * Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0 * Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 0-9705394-2-8 * Component Design by Example, 2001 ISBN 0-9705394-0-1 * VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1 * VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115 --------------------------------------------------------------------------
