tomaThomas's avatar
tomaThomas
4 years ago
Blank window / GUI elements not visible for QSYS and system-console
When starting qsys or system-console, the window stays blank. When clicking somewhere, sometimes a popup is visible, so the GUI elements are there, but not visible.
qsys-edit --debug does not give any output.
I am using arch linux, swaywm and quartus 21.1. Any ideas how this could be fixed?
  • sstrell's avatar
    sstrell
    I don't know if Quartus is supported in your Linux setup, but I'd try an uninstall, re-download, and re-install.
  • KennyT_altera's avatar
    KennyT_altera
    Thanks for using Intel community forum,
    Kindly expect some delay in the reply due to holiday.
  • hareesh's avatar
    hareesh
    hi tomaThomas,
    try to launch system console via below method:
    1. Starting System Console from Qsys
    Click Platform Designer > Tools > System Console.
    2. Starting System Console from Nios II Command Shell
    On the terminal Type the following command:
    system-console
    Note: Make sure you have setup the environment variable for nios2eds
    eg : C:\intelFPGA\19.1\nios2eds
    Let me know if this works
    and if it's not working then share your machine properties details and Quartus version (stranded or pro).
    • hareesh's avatar
      hareesh
      Hi @tomaThomas ,
      can you please respond whether you are still facing the issue or should i close the case
    • hareesh's avatar
      hareesh
      Hi @tomaThomas ,
      Since there are no feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, someone will be right with you.
      If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
