tomaThomas
4 years agoBlank window / GUI elements not visible for QSYS and system-console
When starting qsys or system-console, the window stays blank. When clicking somewhere, sometimes a popup is visible, so the GUI elements are there, but not visible.
qsys-edit --debug does not give...
hareesh
4 years agohi tomaThomas,
try to launch system console via below method:
1. Starting System Console from Qsys
Click Platform Designer > Tools > System Console.
2. Starting System Console from Nios II Command Shell
On the terminal Type the following command:
system-console
Note: Make sure you have setup the environment variable for nios2eds
eg : C:\intelFPGA\19.1\nios2eds
Let me know if this works
and if it's not working then share your machine properties details and Quartus version (stranded or pro).
hareesh
4 years agoHi @tomaThomas ,
can you please respond whether you are still facing the issue or should i close the case
