12 years ago
Bittware S5PH-Q 14.0 flash issue
Hi all,
I have recently upgrade my Bittware card to Quartus 14.0 which previously had 13.1.3. I was able to successfully install the BSP and flash the board with the Bittware provided top.rbf using Bittworks. However, when I did a hard reset, my system will no longer boot. I get nothing.
I am running Centos 6.4 and flashed using Bittworks for linux. I was able to talk to the board again by installing it on my windows machine. I erased the flash and reprogrammed it with the same rbf file successfully. I was able to boot my windows machine and still talk to the board. I re-installed on my linux box and still wouldn't boot. For grins, I installed the board on a system running Redhat 5, it wouldn't boot either.
Currently I am compiling a hellowold using 14.0 and will try to flash with the resulting rbf and see what happens. I was thinking the top.rbf that I downloaded from Bittware may be bad.
Another solution could be to reset the board. I only did the erase command in Bittworks.
All these I will try in the next couple days. I have contacted Bittware but haven't heard back from them yet.
Has anyone successfully flashed this particular board?
  • SteffenP's avatar
    SteffenP
    First, my apologies for resurrecting a very old thread.
    I'm reaching out in desperation. I have a S5PH-Q board but I have lost the original design example files. At the very least I would need the QSF file with the pin assignments.
    Would anyone be able to help me ?
    Sincerely,
    Steffen
