11 years agoBidirectional pin problem
I am using bidirectional SDIO pin for implementing an ADC SPI controller. As the ADC doesn't have separate SDO line, I Am left with no choice but to use the bidirectional pin. The controller takes RD/WR,DATA and ADDRESS LINE as input. In the beginning of each cycle it writes the RD/WR and ADDRESS signal to the ADC through SDIO line. Then depending on the RD/WR signal it switches its polarity to either write DATA into ADC through that SDIO line or read data from ADC using the same SDIO line. I am getting no error during synthesis. But as I try to simulate the same, the SDIO line gets into 'X' state at all those points where a transition in its value is expected. Please help me with the same. I have attached my code and testbench and application note related to the same
