13 years agoBFM in VHDL - from Quartus2 13.0
From the release 13.0 of Quartus2, BFM in VHDL are supported.
Before 13.0, BFM were only supported in Verilog and there was a testbench example in System Verilog found in "Avalon Verification IP Suite Design Example" (ug_avalon_verification.zip) that worked fine. Now I'm trying to adapt that example in a VHDL-only simulation in order to use Modelsim Starter Edition and BFMs with my VHDL custom files. I'm finding some troubles for 2 reasons: 1) VHDL BFM approach is not well documented 2) the differences in hierarchy between Verilog and VHDL. In the Verilog example, the top file and the test_program file were correctly separated and in the test_program.sv with the define you could access every signal in every like this:`define CLK tb.st_bfm_qsys_tutorial_inst_clk_bfm and then use with the dot notation `CLK.clk What is the best way to accomplish this in VHDL? Is there anyone who has already adapted that example? Thank you very much Luca
