13 years agoOk I figured out how to get it to work with VHDL code. I figured out most of the Avalon specifying is done when you add something as a new component. Now I managed to make a slave Avalon-MM device. Well the VHDL code only. How does it look?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity test_slave is
port (
clock : in std_logic;
resetn : in std_logic;
read : in std_logic;
write : in std_logic;
chip_select : in std_logic;
byte_enable : in std_logic_vector(3 downto 0);
writedata : in std_logic_vector(31 downto 0);
readdata : out std_logic_vector(31 downto 0);
to_lights : out std_logic_vector(31 downto 0)
end test_slave;
architecture Behavioral of test_slave is
signal the_register : std_logic_vector(31 downto 0);
begin
process(clock,resetn)
begin
if resetn = '0' then
the_register <= (others => '0');
elsif rising_edge(clock) then
if chip_select = '1' then
if write = '1' then
if byte_enable(0) = '1' then
the_register(7 downto 0) <= writedata(7 downto 0);
end if;
if byte_enable(1) = '1' then
the_register(15 downto 8) <= writedata(15 downto 8);
end if;
if byte_enable(2) = '1' then
the_register(23 downto 16) <= writedata(23 downto 16);
end if;
if byte_enable(3) = '1' then
the_register(31 downto 24) <= writedata(31 downto 24);
end if;
end if;
end if;
end if;
end if;
end process;
if read = '1' then
readdata <= the_register;
end if;
end if;
to_lights <= the_register;
end Behavioral;
