17 years ago --- Quote Start --- The Keep directive seems to have worked!!! I did have hold time optimization setting to all paths but it does not seem to force the necessary routing conditions. Thank you for your interest. The interface is just a simple three wire serial interface running at around 25 - 50 MHz. So it is a source synchronous interface. The CLK signal is generated by dividing down the main clock by 2 using simple logic and the CS_L signal is driven out of the state machine. Since it is relatively low frequency it is ok if the CS_L delay varies a bit as long as it is sometime between 1.5 and 10 nsec after the CLK signal. I was going to put the delay in the CS_L path. We are using Stratix II and I run slow and fast models Certainly I agree with you there should be better ways to do this. Pletz: It would be great to get a second opinion on my constraints if your interested. # Create clock for IO timing create_generated_clock -name VDAC_CLK_PIN -source [get_pins $CLKD_VDAC] -divide_by 2 [get_registers $CLKIO_VDAC] set vdac_clocks [get_clocks $CLKD_VDAC] foreach_in_collection clk $vdac_clocks {set vdac_period [get_clock_info $clk -period]} set vdac_max_delay [expr ($vdac_period - 2.0)] # CS timing # setup time = 8 nsec, hold = 0 nsec (being conservative) skew 1 nsec. set_output_delay -clock VDAC_CLK_PIN -reference_pin VDAC_SCLK_R -add_delay -min -1.5 [get_ports {VDAC_SYNC_L}] set_output_delay -clock VDAC_CLK_PIN -reference_pin VDAC_SCLK_R -add_delay -max $vdac_max_delay [get_ports {VDAC_SYNC_L}] --- Quote End --- Hi jstander, unfortunately I have not so much experience with TimeQuest, but I think your constraints are ok. Maybe I have an (stupid)idea how to simplify your problem. Are data signals coming out of the "fast" clock domain ? Is latency an issue ? Kind regards Pletz
