17 years ago --- Quote Start --- How critical is your output timing ? Using additional inverter makes your timing depending on temperature, device speed, power supply and your routing. If you plan to use the FPGA for a product I think you will run into problems. --- Quote End --- Could you explain a little bit more how the output signals "CLK" and "CS_L" are generated? It sounds for me that you try to implement a "source synchronous" interface. Is the output signal "CLK" directly derived from a input clock ? It would also help when you post the part of the SDC file , where you set your constraints.
