15 years ago
BeMicroSDK_lab altera_avalon_tse.h
i request your help for helping me to fix a problem with my BeMicroSDK_Lab_bsp project.
If i build my project i get a driver problem.
(i've tried:
clean project-build all
made a new project
Hope that the attachement gives enough information....
...thanx
    Are there Altera SGDmas in your SOPC builder project? It looks like the dirvers for those haven't been included in the BSP.
    Thanx for your comment.
    I've downloaded the BeMicro_SDK_LAB_Materials.
    THere is a .sof file included and not a .qpf, so it's not possible to take a look @the hardware design environment....
    I think that the problem is that i've to Disable the uCProbe_uart driver by un-checking the enable check box (this is a step in the included .pdf)???!!!
    BSP editor-->drivers tab--> altera_avalon_jtag_uart_driver -->enable or disable small driver...
    Every time i open bsp editor it says: hardware component altera_avalon_sgdma10.0 does not meet candidate driver ... you may need to re-generate. this has something to do with versions 10.0 and 11.1 sopc file, it's not possible to re-generate this sopc file because i only have the .sof & sopcinfo file.
    Do i things mixed up or...??!!!
    Yes, if you don't haze the original project to regenerate, you may have to use the same Quartus version as the one used to make those files. It looks like the BSP generator can't use the current SGDMA drivers for some reason.
