11 years ago
beginner's issue: register assignment never happens
Another beginners understanding problem..
In the following module I try to provide some input at "writedata", and "write" signal, and expect some incremented output on "readdata" and a "done" signal set. When I test the code with ModelSim, I see the assignment to readdata actually never happens. Actually the line of the assignment to readdata is not even breakpoint-able in ModelSim, it tells "no executible line". Why is that? How may I achieve an incremented assignment here, and what am I doing wrong?
reg  algo_out;
initial algo_out = 8'b0;
EDIT: I posted the wrong code snippet, pls have a look into my other post, below! Sorry about all the mess!
    Oups! Sure, sry!!! I copy&paste'd the wrong version...
    The version, now a bit more tested, but still with the same issue: readdata does not get assigned, is here:
    module avalonmm_algo(
        input clk,
        input start,
        input reset,
        output reg  leds,
        input write,
        input  writedata,
        output reg  readdata,
        output done
    parameter WAITING = 2'b00;
    parameter WORKING = 2'b01;
    parameter DONE = 2'b10;
    reg  stage; // init?
    initial stage = WAITING;
    assign done = (stage == DONE);
    reg  step;
    initial step = 2'b00;
    reg  algo_in;
    initial algo_in = 8'b0;
    reg  algo_out;
    // STEP rules, DATA initialization and handling
    always @(*)begin
        if(stage == WAITING)begin
            leds <= 4'b0001;
        end if(stage == WORKING)begin
            leds <= 4'b0010;
        end if(stage == DONE)begin
            leds <= 4'b0100;
    // TODO: why is this always executed?
        end else begin
            leds <= 4'b1111;
        end
    end
    // procedural assignments for registers
    // clocked STAGE and STEP transition, here
    always @(posedge clk)begin
        if(reset)begin
            stage <= WAITING;
            step <= 2'b00;
            algo_in <= 8'b0;
            algo_out <= 8'b0;
        end else if(start)begin
            stage <= WORKING;
            step <= 2'b00;
        end else if(stage == WORKING)begin
            case(step)
                2'b00: begin
                    if(write)begin
                        algo_in <= writedata;
                        step <= 2'b01;
                    end
                end
                2'b01: begin
                    algo_out <= algo_in + 1'b1;
                    if(0 < algo_out)begin
                        step <= 2'b10;
                    end
                end
                2'b10: begin
                    readdata <= algo_out; // TODO why does this not assign?
                    if(0 < readdata)begin
                        step <= 2'b11;
                    end
                end
                2'b11: begin
                    stage <= DONE;
                end
            endcase
        end
    end
    endmodule
    Questions: as above and the comments I had, perhaps you still could have another look on it, and give me some hints?
    I tried a quick check and I see read data acquiring values. It is likely your inputs or expectations are wrong
