12 years ago --- Quote Start --- Quartus II, version 10.1, Cyclone II. I'm newbie in Verilog. I need a block: module (input x1,x2, output reg Y); if (positive edge of x1) Y=0; if (positive edge of x2) Y=1; I tried "always @(posedge x2) begin zliczaj=1; @(posedge x1) zliczaj=0; end" but i had error "multiple event control statements not supported for synthesis". I tried "always @(posedge clear) zliczaj=1; always @(posedge pelne) zliczaj=0;" but i had error "can't resolve multiple constant drivers for net 'Y' at ....". How to do that? --- Quote End --- you should drive Y only on one clock edge. you better have a clk faster than x1 ,x2 then use x1 as enable to drive '0' on Y and use x2 as enable to drive '1' on Y (within the same clocked process). This will drive Y on the clk edge but not on x1,x2 edges. If you mean by x1 or x2 edge its transition fron 0 to 1 sample then you add extra logic as your enable.
