15 years ago
Basic question
Learning Quartus II: When I create a schematic sub-block in the main schematic block design file, the compiler will not recognize connections in or out of the sub block. I have named the signals in and our the same, but no luck?
    --- Quote Start ---
    --- Quote End ---
    can you post your bdf-file ?
    Kind regards
    GPK
    Hello Pletz,
    Thanks for replying, here is the project in zip file which produces the compilation error.
    This is a simple project consisting of an input pin, connected to a sub-block that contains a nand gate, then back to an output pin.
    Arthur
    In your top schematic, you have an empty sub-block, not the intended subblock-schematic. You have to insert the correct sub-block or rename the "block_name" block.
    P.S.: Your sub-block has no in- and output ports. So it can't be connected.
