8 years agoBasic question about Signals
Hi, I'm beginner in VHDL; My Question is ; when we define a signal as std_logic, but without any value. Is it same of saying that signal's starting value is '0' ?
8 years agoclk_50mhz <= not clk_50mhz after 20 ns /2 ;
Here the clk starts and 'U', and the NOT of 'U' is also 'U'. So yes it needs to be initialised. There is a handy workaround so you can do it without initialisation, if you dont mind using a process (but it means you can add other handy stuff to the testbench):
clk_gen_proc : process
begin
if clk /= '1' then clk <= '1';
else clk <= '0';
end if;
wait for CLK_PERIOD/2;
-- Timeout Control. Stops the testbench after G_TIMEOUT clocks without a "normal" finish
if NOW >= G_TIMEOUT*CLK_PERIOD then
report "Simulation ended due to TIMEOUT" severity FAILURE;
wait;
end if;
end process;
