11 years agoat the end what matters is who should look after such strage violations; the tool or the user.
You enter PLL rx clk as 300MHz(3.333 period as displayed by wizard) then you supply that clk and enter sdc as 3.333 If the tool gets it wrong then it is a bug by definition. I haven't seen anywhere in TQ advice about rounding issues with respect to figures for clk period. I also entered sdc as "300MHz" instead of period and ended up with same strange violations. Certainly the device seems to achieve such speeds at periods below or above 3.333
