9 years agobasic always block question
I have questions about always blocks. Both will use the following always block for context:
always @ (posedge Clk)
begin
if (x1)
q <= 1;
else if (x2)
q <= 0;
else
q <= q;
end
9 years ago --- Quote Start --- Would this code 'prioritize' checking x1 before x2? --- Quote End --- Obviously yes. --- Quote Start --- What would happen if x1 and x2 were both high? --- Quote End --- The same as only x1 high? --- Quote Start --- How exactly would it synthesize? --- Quote End --- Any logic fulfilling the behavioral description would be correct. In FPGA as D-FF with preceding logic. You can watch the synthesis result in Quartus post synthesis net list. --- Quote Start --- Also, if I want q to retain it's value, is it necessary for me to explicitly code that in the form of q <= q? or is there another way? --- Quote End --- The final else statement is redundant and can be omitted. A register keeps the previous state by default.
