10 years agoBarrel shifter coding using mux
I need help building a barrel shifter that uses multiplexers and has three columns as stated in the attachment. Please help!
10 years agolibrary IEEE;
use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.all; entity barrel_shifter_8bit is Port ( data: in std_logic_vector(7 downto 0); data_out: out std_logic_vector(7 downto 0); ctrl: in std_logic_vector(2 downto 0) ); end barrel_shifter_8bit; architecture Behavioral of barrel_shifter_8bit is component barrel_shifter_8bit1 is Port ( input: in std_logic_vector(15 downto 0); data_out: out std_logic_vector(7 downto 0); ctrl: in std_logic_vector(2 downto 0) ); end component; component barrel_shifter_8bit2 is Port ( input: std_logic_vector(15 downto 0); data_out: out std_logic_vector(7 downto 0); ctrl: in std_logic_vector(2 downto 0) ); end component; component barrel_shifter_8bit3 is Port ( input: in std_logic_vector(15 downto 0); data_out: out std_logic_vector(7 downto 0); ctrl: in std_logic_vector(2 downto 0) ); end component; signal sig1, sig2: std_logic_vector; begin unit1: barrel_shifter_8bit1 port map (data7 =>input0, data6=>input1 and input2, data5=>input3 and input4,data4=>input5 and input6, data3=>input7 and input8, data2=>input9 and input10, data1=>input11 and input12, data0=>input13 and input14, input0 => 0); unit2: barrel_shifter_8bit2 port map( unit3: barrel_shifter_8bit3 port map() end str_arch; with ctrl select data_out<= data(0)& data(7 downto 1) when "001", data(1 downto 0)& data(7 downto 2) when "010", data(2 downto 0)& data(7 downto 3) when "011", data(3 downto 0)& data(7 downto 4) when "100", data(4 downto 0)& data(7 downto 5) when "101", data(5 downto 0)& data(7 downto 6) when "110", data(6 downto 0)& data(7) when "111", data when others; end architecture Behavioral; ---- what it looks like now working on port mapping the three columns of barrel shifters. The last part is from some help I got earlier for the first column dont know how to use it yet.
